Rock Lights. What are you guys running?
I'm using the Cyclone LEDs from KC. About $20 each - but very rugged, small, easy to mount with the center hole and quite bright.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=608493"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=608492"/>
Figured I would update this. I decided to install these last night. Besides for being time consuming it turned out pretty good. For lifted Jeeps it'll be a lot easier to get the lighting even around the vehicle. Where my lights are positioned, without a lift makes them too focused and not spreading like they should. This is changing soon, though! I installed these on a hoist and positioned everything with the Jeep raised in preparation for my next phase.
My cell phone takes away some of the light that these produce...it's a lot brighter than it appears.
Attachment 608894
Attachment 608895
Attachment 608896
Attachment 608894
Attachment 608895
Attachment 608896
I like this, however, I'm running a full Rock Hard Skid plate which really limits where I can put my lights. You've got a big black square in the middle which shouldn't be a problem as that area is all steel on my jeep, but do you think it could be eliminated with a couple additional LEDs? Maybe the 12 LED version instead of the 8 would be better.
Hopefully I'll have some time next month to get my lift and front axle completed. Going with coil overs and 37's. After that, I'll make up my mind whether additional lights are needed. I didn't cut any wire yet, everything was coiled and zip-tied just incase I want to change something after I lift.
