Rock lights
Old 09-08-2008 | 04:34 PM
greenmachine07's Avatar
here is a night shot of the lights i already posted
http://i287.photobucket.com/albums/l...1/DSC00265.jpg
http://http://i287.photobucket.com/a...1/DSC00265.jpg
Old 09-08-2008 | 08:02 PM
gogrlgo's Avatar
Old 09-09-2008 | 07:29 AM
ghostdancer308's Avatar
Default rock lights
Looks good! What kind are these?
Old 09-09-2008 | 04:39 PM
gogrlgo's Avatar
Not sure I got them from Advanced Auto Parts.
Old 09-09-2008 | 07:17 PM
Rubimon's Avatar
Hmmmmmm! I might try this. Who has LED ones? Pictures???
Old 09-09-2008 | 07:29 PM
whpony96's Avatar
I purchased these. hXXp://www.oznium.com/prewired-superflux
I have 2 in front and behind each tire for a total 16! At $2.99ea you cant beat that!
These LEDS are all waterproofed, with a built-in resistor and a foot of wire, so all you have to do is plug them in. LEDS use little electricity and give off virtually no heat, so you won't have to worry about a fire with these cool lights.
They are ready to go - "pre-wired" to work on any 12 volt system.
Just hook up the red wire to positive, and the black to negative (ground).
A superflux LED is square LED, with a very wide viewing angle. And our superflux LEDs have not just one, but FOUR chips in one LED for ultimate brightness. They can mount in a 3/8" hole.
Here's how it works: we glue each superflux LED into waterproof housing and pre-wire it, so it's ready to go. You simply hook up the red wire to positive and the black wire to your ground on your 12-volt system and you're in business! These lights are FOUR LEDs in one, so they're bright enough for all of your needs, and they mount in any 3/8" hole, so you can use them just about anywhere.
Old 09-10-2008 | 05:48 AM
Littlejon's Avatar
I know that Ron at wanderingtrail.com has a write up with pictures of the ones he did.
Old 09-10-2008 | 07:08 PM
Optus's Avatar
regardless of where you get them, how much on average would a setup like this cost? i just dont know anything about lights so just curious as to how much they would cost.
Also, are there any laws regarding undercariage lighting? More specifically for Maryland?
Old 09-10-2008 | 07:13 PM
Rubimon's Avatar
Might not be legal if you run it with them on the street! They are for offroad!
Old 09-11-2008 | 07:06 AM
hunter0781's Avatar
wanderingtrail.com/Mods/JKmods/Tantrum/Tantrum.htm
Quick Reply: Rock lights
