Rigid Dually LED Lights Tied Into Factory Fog Light Switch
YA,That's what i'm going to do.I have a harnest made up already w/ a relay.Just gonna go that route and be done with it.
I recommend you put them on a separate switch. I had dually's wired direct into the stock harness and after the jeep was shut off they would sit there and flicker. I read that canceler capacitors would fix this problem so I installed some and they fixed the flicker after shutting the jeep off, but now they will randomly flicker when it is running . I have them unplugged right now until I wire them on their own switch because the flickering was getting annoying.
