Rigid Dually flickering only while jeep is running
ok heres the problem i had a set of rigid dually spots on my windshield they flickered so i sent them back ...got the replacements today and put them on the jeep ..these new ones only flicker while the jeep is running shut off the jeep they are fine ...check connections etc found nothing im at a loss anybody have any ideas ..i really like these lights but this is set two that flickers ...i also have floods on my bumper and they dont flicker at all ....i just dont understand
Sponsoring Vendor
ORW Representative
ORW Representative
If all the connections are good and tight, I would have to guess that there's still an internal issue with the lights. Try disconnecting then reconnecting all connections. The lights are wired independently straight to the battery?
If that doesn't change anything, I would contact Rigid again and see what they have to say.
I had the same issue with mine and it was caused by the connections to the switch. I replaced Rigid's stock switch with a Daystar, but the connections didn't fit. I opened the connection up enough to fit on the post of the Daystar switch but didn't tighten it up enough afterwards. Luckily, I tested before putting the a-pillar back together. I only needed to use some needlenose pliers to get into the tight spot and squeeze the connection together.
I hope it's that easy for you too. Good luck.
