Rigid back up light install question
#43
I am ordering D2 diffused flush mounts in the morning. I will have them in ASAP. The Duallys put out an incredible amount of light (have them installed now); I can't imagine what the D2s are going to be like!
#44
#49
I wrote this somewhere, but a word of caution when installing. The angled corners of the flange are a bit*h if you over cut your vertical and/or horizontal lines. I know from experience. Use a cutoff tool for the main parts of your cuts, then use a sawzall to be very careful in the corners so as to not overshoot the cuts. You can see my over cuts just a bit in two places. Most will never notice, but it pisses me off knowing they're there (I'm a perfectionist when it comes to mods!). You can see my over cut in pic #2. Also, I have these on a three way switch (on-off-on) to go on in reverse or constant. Having these go on when I go to reverse is awesome. The light output is incredible.
#50
Has anyone mounted the rigid flush mounts on rear stock bumper? I am going to crawl under my rig tomorrow and see if there available cavity in the center or sides similar to Bob's.
