The Right Way to Solder?
I can agree with most of what you say there, but i have taken remote start systems that were even poorly installed and found no corrosion at all. The theory behind the poke and loop is that it creates enough of a barrier to keep a high % of the air out and creates a large enough surface initially when made that even if left untaped or shielded the interior of the connection should remain unaffected. I have seen galvanic reactions on wires of dissimilar types caused by excessive humidity or in a flooded vehicle. Guess that would be something to consider in a jeep that might get the electronics wet
I learned more about wire termination them I think I ever wanted to know workin at amp/tyco. They basically wrote the book for wire terminations, so I had more training and specs then I knew what tp do with. I left there two years ago and now you made me feel like Im still there Thanks alot back to therapy
Well, I looked through the postings and didn't see several very salient points mentioned:
1. You don't want a cold solder joint. That was mentioned. But, what does that mean? You want the solder to have a shiny appearance. If it appears dull and/or mottled, it's a cold joint. Cold joints are bad because they are mechanically weak, and because they allow corrision to start.
2. Solder itself is mechanically weak. The mention about not using solder on stranded core wires in bundles is right on (27-1/2 years aircraft avionics maintenance experience here). But, I won't re-open that argument--solder if you wish. But the important thing to note is that you can't depend on solder to give a mechanical connection. You need to properly twist the wires for that (which is another mark against soldering stranded wire--they don't twist very well!).
3. Finally, since I know you're probably going to solder despite my warning in 2: Rosin core solder is for electronics/electrical wiring. Acid core solder is for sheet metal work (try it on electronics only if you don't mind lots of corrosion on your work). Silver solder is for specialized applications (say, sensitive circuitry inside your GPS).
4. Oh, one final thought: If you're just soldering wiring harnesses, you don't have to worry too much about too much heat (try to avoid melting the insulation, though!). But, inside electronics or near (electrically "near", not physically "near") sensitive components (say, a wire going into some embedded computer on the JK), voltage from the soldering iron tip can destroy the nearby electronics. If you think you're going to be soldering near some piece of electronics that might be damaged by stray voltage, either disconnect the electronics (if possible), or use a soldering iron designed for that type of work.
Edit: Added 4.
Edit: Added 4.
Thanks for all of the input.
I am going to try to pick up a soldering iron today and mess around on the bench before i go to work on the Jeep.
Thanks again!
Scott
Thanks again!
Scott
Be careful, and put something solid under your work to protect the area. You would not be the first to drop a hot blob of solder on your interior or carpet.
If your hands are shaking, take a break until they are not.
For stranded wire use crimp lugs, soldered wires will break due to vibration.. Of course Jeeps don't vibrate so you don't have to worry about that.
If you need them water proof, put a piece of heat shrink large enough to slide over the crimp connector first.
Ive been soldering wires in vehicles for over 10 years as an electronics installer, when done right, soldered wires do not break due to vibrations.
Believe me, Ive seen and fixed my share of other peoples very bad installs, cold solder joints, over heated joints, you name it, but never have I ever seen a broken solder joint or a broken wire from soldering!
I have also seen many bad crimp lugs/caps/butt connectors whatever you want to call them...whether it be over crimped, broken, pulled out, wiggled out, corroded, they just suck!
In my 10 plus years of installing and soldering, Ive never had to fix any of my own connections
why solder?
The object is to obtain a mechanically secure, gas-tight union. A properly sized wire nut does the BEST job when space is not an issue. As has been hinted at, gas-tight is always important. But gt is especially important in low voltage, low current signalling circuits! Your headlights might work for years with the poke and twist because the current is high enough that the increasing resistance isn't a factor. Not so with digital inputs to modern electronics! How to tell if you are using too much heat? 1) The insulation melts (duh!) and 2) solder is wicked into the wire well beyond the juction area creating a stiff single strand wire from your nice flexible stranded one. Crimp unions and terminations are only recommended if you have high quality terminals that are PROPERLY sized and applied using a high quality (preferably calibrated) crimper. Cheap terminals relax the crimp and corrode. Cheap crimpers (NEVER pliers!) either do not crimp tight enough to create the gas tight connection or crimp TOO tight damaging the wire and turning your 12 ga wire into a 16 ga wire. Oh yes, my credentials. I have 1.5 million years of racial memories that qualify me to make this response.
That is not true....
go to the bottom of this page and look at the heat shrink butt splices.
http://www.crowbarelectricalparts.co...Connectors.htm
--mark d.
