Replacing Stock Infinity Sub
I am looking at replacing the stock sub with an aftermarket sub. The aftermarket sub is 4 ohm SVC. Would this pose a problem with the current stock Infinity amp configurations? What would the wiring be for the after market sub?
Thanks!!!
Thanks!!!
I was playing around w/ it last night, trying to see if stock enclosure would fit under drivers seat... had the seat out and all. NO WAY Just not enough room. And even making a small box under there would be so tight on space.
I did hook up a 4ohm dvc sub i've got in parallel to just one output on the infinity amp and, like stated above, it struggled. Even though my sub is much better than the paper/foam garbage w/ an Infinity logo on it, it didn't sound as good due to power issues.
Now that I'm thinking about it though... wonder if the stock amp could run bridged 2ohm??? Or bridged at all??? If so, 4ohm dvc in paralled = 2ohm. Run it bridged to stock amp and maybe, just maybe, get a little more power. Hmmm... might try that and if/when it fries, go back to stock and let dealer warranty. If i get around to this, i'll post up.
RB
