Replacing PIAA light switch with plasmaglow. Need wiring help.
I just picked up a set of PIAA 520's and a set of 540's, but I can't stand the cheesy little switch PIAA includes in their kit. I ordered plasmaglow (round push button, illuminated ring when on) switches which will be mounted on the a-piller trim piece (copying mattgt5 and countless others). My questions are related to the wiring. Can I hook up the red, white and black from the PIAA switch leads to the corresponding color leads coming off the plasmaglow? Could it be that simple? Is this switch compatible with the PIAA relay/harness?
I know with all of you experts out there, at least one of you has this type of set up or at least the plasmaglow light switches with similar off road lights. Help a newbie out!!!!
Thanks!
Thanks!
