Replacement LED Brakelight Trouble
Anyone else out there had problems with the Rampage replacement LED brakelights for the JK? I had these on my 2000 TJ and had to add a special flasher but the JK replacements are supposedly "plug and play". I installed them last night and now have the super fast flash for several seconds (until the the resistor heats up I guess) and then the flash is normal? Anyone else encountered this and is there a simple fix?
I believe the JK flasher is built into the instrument cluster = no replacement.
May need to add resistors to the turn signal wires.
What's the product part # you installed? Can't find Rampage replacement tails listed for the JK.
Call Quadratec or Pilot. I believe the first run of the product didn't have the needed resistors, but thought it was fixed.
Again, you can always add a small additional resistor on each side to the circuit. But I agree that for that money and with factory connectors, you shouldn't have to.
