Replace just 6 1/2" stock speakers?
Old 05-16-2008 | 10:05 PM
artpics's Avatar
Originally Posted by Joker92
Thx
Did you replace yours with the Polk's or another brand?
Did you replace all 4?
If so, how much of a difference did you notice from the (under) dash?
No i have not replaced the under dash speakers but will soon, just need enough time for an install there is a write up here of how to do it but seems a bit fiddly, i will presume though that they will sound a lot better as the speakers are in boxes.
and yes i am using Polks. Also you may want to fill the soundbar with poly foam or some stufing from a pillow case as they are quite bright sounding.
here is a great link for the front removal.
https://www.jk-forum.com/forums/show...hlight=removal
good luck and enjoy
Old 05-20-2008 | 02:25 PM
Wranger X's Avatar
I used the polks in all 4 locations. They do sound good but like he said they take about a month or so to break in. I put them in back in Feb. and til this day I still notice the sound gets briter. I also added some poly fil in the 4 locations, it deffinatly makes a difference. You can use the regular polks no need to get the slims.
