Replace fog lights with off-road lights but keep factory switch?
#21
Originally Posted by DJR
I know little about electrical, but I had a similar issue and it turned out to be a wattage didn't match up. I would check that again.
Edit: just looked at the factory fogs and they are 42 watt. I guess the system just sees an overcurrent and shuts them off.
#22
What did you end up doing to fix this? I tried to install a pair of Hella 500 55 Watt lights today and have the same issue. The lights come on for a second then shut off. If anyone else has an idea about the easiest way to fix this I would greatly appreciate it.
#24
The only way to get around that will be using a relay triggered off the OEM circuit.
Just a note... for those doing this, unless there's a fix to keep the fogs on with the highbeams (I don't know if there is, I haven't looked into it), you're aware that you're driving lights will go off when you turn your highbeams on - right?
That's what I figured about the lights and the relay. I guess at least the hella kit I picked up came with a relay. What is the best way to wire this? Can the Ground's on the hella's stay tied to the grounds on the factory fog lights. Then just splice a relay into the power wire from the factory lights to the power on the hella's and run a wire back to the battery with an inline fuse?
#25
Wire question?
Im installing my Hella 500's with led bulbs tomorrow. I havent looked at the wiring yet but can someone tell my what color wire is power and which is ground?
#26
So if I understand this correctly:
86 is tapped into the power supply comming from the switch factory power line?
85 goes to ground...do you find a new ground or tap the factory ground wire?
87 do you tap the lamp ground to the ground wire or to the frame?
#27
#28
#29
86 would be spliced into the ( + ) wire comming from the TIPM. I don't know which is which either. Use a test light.
85 to ground. I'd say find a new ground.
87 goes to the new ( 12 volt + ) wire on your new lights. Since this is a new additional system - use a new ground.
#30
Cut the wiring to your OE fog lights.
