Removed e-disco question
For those of ya that removed your electronic sway bar in favor of a stock sway bar or Anti-rock, what did you do with the harness? Zip tie it? Cut it?
Sent from my thingy.
Havent done this to mine. I personally hate cutting up a stock harness so when i remove somthing and have an open plug i cote the terminals in dielectric grease then put a small bag over the terminal and wrap it up to seal out moisture. Then i just tuck it or zip tie it up out of the way.
I removed my e disco for a evo no limits disco... The harness I taped the end so it's sealed and zip tied it out of the way.... The light on the dash u need a procal to turn off
Sent from my Samsung Galaxy Tab 10.1 using Tapatalk 2
