Remote Keyless entry change...
If I could change one thing about the remote keyless entry and alarm, I want it to also lock the center console when I use it. It seems like a simple change but I have only a vague idea of where to start.
With this, why not add the glove box to it while I'm at it?
That is a very Strong Con... The electric unlock would be self-defeating. If the top is off, they simply unlock it and go. If it is manually locked they have to break into it.
box
lets face it, on my TJ, its a PLASTIC lock, I assume the JK uses a plastic cover on the glove box too..
A small crow bar would make about 10 seconds worth of work for your glove box...
if they have your key unlock fob, u have bigger problems...
You would need to design a locking mechanism similar to the door locks, then just split it off say the passenger door lock at the wiring harness
it could be done, but it would be a lot of work..
ohh, and the roof unzips... so yea...
you could wire in a 1 way diode so that to lock / unlock the glove box u need the key fob. or use a seperate one...
