Relocating factory fogs - keep oem or use plug and play replacement
I'm working on a custom bumper and need to relocate my factory fogs. I have no urge to try and cut holes in the new steel for fog lights and would like to mount them just above the bumper.
Is there a way to make a decent looking light bucket for the factory fogs or is there an aftermarket bucket?
I found these http://www.quadratec.com/products/97047_1000.htm and I suppose they would work though I'm not loving the price.. Anyone know of other after-market versions?
I know I could buy aftermarket lamps and just make a new switch, and while I will probably do that eventually, I would really like to keep the factory switch and wiring harness.
Any ideas would be greatly appreciate it.
2011 Unlimited Sport
Thanks!
Thanks!
I just bought those same lights, new on eBay for $80 shipped. Shop around. They are made by Hella and the search is for Hella FF75. Otherwise any 55 watt auxiliary light will work without too much, if any creative wiring.
Eternal ***erator
See this thread for pictures/description of light bucket using 3" PVC pipe caps: Housing for Factory Fog Light?
Originally Posted by JK-Ford
And it's easy to screw up your electrical system too. And, it's not realy that hard to do it right.
Do both, cutnthe wires!!! Solder and heat shrink, or butt connectors and do the PVC buckets and relocate , and grab a cheap set of off-road lights with a relay kit and use the factory switch to trigger them....
Hope I'm making sense...
