Recon LED issue
Recon LED issue
Just installed my Recon Led Turn Signals. I used the supplied resistors. The bulbs will flash at normal speed once the key is on, then after about 5 seconds, the hyperflash. Each side will do this one time when activated after turning the Jeep on, then flashes quickly until the next time I start the Jeep. The resistors are installed one end on the black wire and one on the turn signal wire, used a testlight to ensure I had the right wires. I'm lost, any ideas? Any and all help is appreciated.
