Recon front turn signal help
Hoping someone knows a way to get my recon LED front turn signals to flash at the correct speed. they flash very fast which i have learned is because they draw such low amperage the jeep thinks i have a burned out bulb. really dont want to use the big hot load resistors that came with the kit. Is there another fix?
Hoping someone knows a way to get my recon LED front turn signals to flash at the correct speed. they flash very fast which i have learned is because thr draw such low amperage the jeep thinks i have a burned out bulb. really dont want to use the big hot load resistors that came with the kit. Is there another fix?
Autozone sometimes has load resistors that are smaller than most. Though they also get very hot. $10 for a set of 2.
On my buddy's CJ when we swapped to LED tails we added incandescent rear side markers to the circuit to provide the needed load.
