Rear lighting
Rear lighting
Has anyone add lights in the rear to help backing up in the dark cause you can barely see anything ? I couldn't find much, but maybe you guys have.
I believe it was just about writing lights. I'm looking for possible ways a light could be conveniently mounted in the back.
Heres some threads on where people mounted their rear lights
https://www.jk-forum.com/forums/jk-e...-236745/page3/
https://www.jk-forum.com/forums/jk-e...ghts-168038/#b
https://www.jk-forum.com/forums/modi...ures-295654/#b
20Rubycon15 (02-03-2023)
I made a custom bracket to hold my plate and I decided to mount the Hella 6 LED light. It is wired on its own switch and power source. I also installed the lightnin' bolts for the plates. The pic looks dimmer than they actually are.
I replaced my back up lights in the stock housings with LED bulbs, they work great, plug and play no new hardware to mount of anything to mess up in the wiring.
I added a Blitzpro hawk 6D underneath my Jerry can carrier and swapped the factory bulbs for led replacement sorry best pic I have of the rear light
sent from my obama monitoring device
I like the set up. How did you make the mount? Can it be done with stock tire carrier?
Does it block access to the rear door handle? Can't really tell. Haha. I like it though
