Raxiom Aux Cube Lights
placement for cube lights
First two questions that come to mind are "where are you gonna mount them" and "do you want them on a separate switch or are they going to use stock bumper lights control and wiring".
I am mounting them on the lower front corner of the windshield and will use separate switch/wiring. What are your thoughts on location and wiring?
Thanks!
Thanks!
I am trying to keep the interior as stock looking as possible so as not to draw attention to my upgrades when the top and doors are off so I modified the stock switch module to include controls for my amp and interior LED lighting. There are photos it on my profile. I see ads for putting a block of switches on the A-pillar but I didn't want unnecessary lights (from the switches) in my view. if you plan on adding more things, these switch pods are convenient and some come with a power distribution block for under the hood to have one power source with circuit protection Since you are wiring it separately and not using stock control & wiring, you don't have to worry about the CAN bus which can be very temperamental to electrical add-ons.
