Rate my new stereo system!
Old 05-13-2012, 02:09 PM
MoreOvalteenPlz's Avatar
It'll sound badass! I have mine to where I can put in 2 15" Kicker L7's in a 6 cu ft box(have to take out the back seat of course), or I can put one kicker comp in a Scosche box from walmart behind the back seat. I use a Kicker ZX 1500.1 amp to power both setups. I'm Savin up for a dual 12 box and two 12s that can handle 1500 watts...
Old 05-13-2012, 04:04 PM
lolpetewtf's Avatar
Originally Posted by kh202
I won't fit under seat. I just have mine laying flat behind rear seat. Fits perfect. No need to mount it, really does slide around much. Leave enough slack wire so you can set it on the ground to take the rear seat in and out.
Attachment 316466
Thanks for posting that. I figured it would not fit under the seat. I will find a way to install it without sliding around, with and without the seat in. Where did you mount the amp?
Old 05-13-2012, 04:07 PM
kh202's Avatar
The amp is underneath the sub in the floor storage bin... With the legs on the box, it really doesn't move much. I'd just put a piece of rubber on them if ur really worried about it
Old 05-14-2012, 08:50 AM
ThwopKing's Avatar
Should be ok for now...but i would save up for a better amp than BOSS....they make fleamarket quality stuff.
Old 05-14-2012, 01:07 PM
lolpetewtf's Avatar
Ya I was thinking the same thing. Just want to see how it will work out for now. I can afford better, but ya know, I'm a cheap bastard
Old 05-14-2012, 08:26 PM
ThwopKing's Avatar
if you can afford better...why waste your money on junk?
Old 05-15-2012, 12:43 PM
lolpetewtf's Avatar
One thing just came to mind, how can I run the tweeters off the head unit too? Wire them together with the fronts, or is that a really bad idea lol??
Old 05-15-2012, 01:15 PM
Shecky's Avatar
Bad idea, unless you have a crossover or a bass blocker to cut the low frequency to the tweeters
Old 05-15-2012, 01:35 PM
shakeman0's Avatar
I had my tweeters installed, but I'm pretty sure the ones I got had special frequency blockers built into the wiring to automatically block the low end frequencies.
EDIT: Yep, they have in line crossovers. http://www.crutchfield.com/p_107DB1001/Polk-db1001.html
I'm actually really happy with the Polk tweeters. They have a great crisp sound on the highs. I would be a little wary of getting them without an after market HU though. They were pretty overpowering until I did some fine tuning on my 7 band EQ to balance out the bass and highs.
Old 05-16-2012, 01:55 PM
lolpetewtf's Avatar
Getting an aftermarket harness would require no splicing right? worth it to get one?
Quick Reply: Rate my new stereo system!
