Rack Causing Sirius Interference :)
Old 07-30-2008 | 07:00 PM
WooPig's Avatar
Default Rack Causing Sirius Interference :)
I installed a Gobi rack on my unlimited last weekend. It looks great, but I soon discovered that my Sirius radio is now experiencing a loss of signal. I never had a problem with the radio prior to the roof rack install. I guess the expanded metal floor and tubing of the rack are causing the Sirius singal to be obstructed. Does anyone have any suggestions on how to fix this issue? I have not taken the time to find the Sirius antenna yet, but I figured it would probably have to be relocated outside of the Jeep. Is the antenna weatherproof?
Old 07-30-2008 | 07:23 PM
TBJK's Avatar
He pretty much hit it right on the head. Run your cable behind the corner moulding (A pillar i beleive). You will have to remove you sun visor to get the cover off. It all tucks rather well.
Old 07-30-2008 | 07:24 PM
TBJK's Avatar
Yes it is.
Old 07-31-2008 | 12:37 PM
WooPig's Avatar
Thanks guys. I figured that would be the case. A magnetic antenna that I could stick outside should do the trick.
Old 07-31-2008 | 12:48 PM
WooPig's Avatar
Hey MaloCS is this the one you used?
Quick Reply: Rack Causing Sirius Interference :)
