Questions about uConnect
I suspect I know the answers but...
My 2010 JK came with the base radio - no uConnect button. I found a 2007 RES radio with the uConnect button on eBay, and bought it very cheap. Then I bought the uConnect module and the iPod cable.
I installed the uConnect stuff today, then went to the dealer to get a Starscan.
The dealer said they couldn't "see" the right stuff, and blamed it on my 2007 radio. They said I had to have a 2010 radio as the bus had changed. I thanked them and went on my way.
Well, I tried the setup, and the voice commands and Bluetooth work just fine. Quite impressive actually. I can't figure out how to make the iPod cable work though.
When I plug it in, it starts charging my iPhone - I do get a message on the phone saying something about this accessory may cause interference. I press AUX on the radio, and it tells me nothing's connected.
Is this because I have a 2007 radio in a 2010 JK? I'm 100% sure I have everything installed correctly and plugged in.
Thanks
Thanks
I think the change was made mid to late 2007, the good news is, if you find a 2008 or later radio, you should just be able to plug it in without another trip to the stealership. I swapped the radio out of my 2007 JK for one out of a 2008 when I got my uConnect working, but my iPod wouldn't work.
Cheers
Cheers
Cheers
Cheers
I probably won't find a bargain on a radio like I did. The 2007 RES cost me $10 + shipping on eBay.
Thought I'd follow up on this old thread. It was the 2007 radio. I got a 2008 REQ and the iPod cable works just fine.
I now have an iPod velcro'd to the back of the glove box and happy as a pig in mud.
How much did all the u connect stuff cost? I also have a 2010 stock radio and would love to swap out for a nice stock higher end radio.... If my DVD nav deal falls through....
I think wyckoff sells the kit for a little over $250 with the uconnect module and ipod cable.. thats what i paid for mine a couple years ago.. then the dealer usually charges .5 hour labor to scan it into service...(assuming you install it yourself first)
-Christopher
-Christopher
I paid $80 for a used REQ + about $300 for the uConnect at the stealership, and I believe another $50 for the iPod cable. The dealer charged $75 to to the Starscan.
