question for every one
According to the Sticky in the modified section the Rubi wheels are 7.5" wide. as for the tires, most manufactures have a recomended rim width in their tire info.
First, welcome to the forum. Lots of info here...you just have to search for it.
If you go to the forum home page each section is broken down for you. Modified JK Tech, Stock JK Tech, (where you will find the answer to your question) JK electronics, this is to name a few. All you have to do is search for it. BTW the answer to your question is 7.5" Hope this helps.
Cheers
Cheers
