Question about headlight upgrade
I completed an upgrade to the RallyLights Hella HID kit with the Phillips extreme 80 bulbs. Installation was easy, took about 25 minutes. My question is this:
The wiring harness connects to the stock wiring harness on the passenger side. Nothing connects to the driver side stock wiring harness. What do you do to "Plug" that harness from water etc? Filling it with silicone sounds like a good option, but is also a pretty permanent change, or at least would be a real pain to reverse in the future if I ever needed to. Any other ideas?
I thought of maybe popping the bottom off of one of the old bulbs, clicking that in, and then electrical taping the heck out of it.
Thanks in advance!
Thanks in advance!
Any time I have an opportunity to unplug an electrical pigtail, I coat the connections with dielectric grease. It works really well to keep connections clean and dry whether or not you're going to plug them back into anything. In your case then just tape over it, but you'll have prevented any water, dirt, or rust from fouling the connection in the future.
Thanks in advance!
Thanks in advance!
