Problem with my KC lights...
I have had my KC lights mounted on my winsheild for about 2 years and they have always worked fine...The other night I went to switch them on and nothing happened. Both lights will not work at all.
I checked my lights, connections, switch, and fuse and they all seem fine...
Just wondering if anyone else has encountered a similar problem or would have any advise.
Thanks,
Crampt0n
Thanks,
Crampt0n
Use a test light or volt meter to see if the lights are actually getting power???? could just be the bulbs. If no voltage to the actual lights then possible bad relay if all else checks out ok....
also check the white wire you ran to your switched source, maybe it came loose. as stated by the guy before me, swap the fuse because it might have been a weird break.
