Power your cb
Wire the CB directly to the battery for best results.(both positive and negative) There should already be an inline fuse on the power harness that came with the cb.
Would you loose reception quality if you used one of the fuse block like the Blue Sea one? Should it matter as long as the main terminal is powered straight to the battery?
I would like to run my power and ground right off the battery but my question is what is the easiest way to get to the battery with wiring from the inside. I took a quick glance this morning a decided I would wait cause I didnt see anything that would lead me out of the firewall. I also need to come through for my lights on the bumper andthe lights on the windshield frame.
P.S. Use an accessory circuit from the fuse box for a power supply.
