Portable Air Compressor Hardwired??
Looks good!, Still trying to figure out how to do a hard wire install. I just dont understand why I would need a tank if I only want to use it for air in the tires? I know how to run all the hard lines to a relay and such, but not sure how to disassemble the switch to run my own I want to keep mine in the rear cubby though.
What size relay do I need?
If it was me, I wouldn't run a tank with the HF compressor... you'd have to add an additional pressure sensor relay, buy brackets to mount the tank, plus all the hardware... by the time you do all that, you'd have a kick ass setup with a cheap ass compressor. I'd keep it simple as possible.
Just my
There really is no need to disassemble your switch. I would leave it there and just keep it in the on position. It'd be nice to have a backup switch to shut it down at the compressor if needed. In fact, I would used the "stock" wiring (just cut off the battery clips) to run forward. through the firewall, to the engine compartment, and tie it into the relay near the battery somewhere... The stock wiring would be fine, especially since almost all all of it is running inside the jeep.
Just my
Just my
I hear ya, I don't want a tank at all. I just trying to figure why some people were saying I might need one.
So if I cut off the jumper clips, run the wires to a relay then to the battery. Then put a switch in the cab and run that to the relay and leave the compressor's stock switch on. I could control the compressor from my fabbed switch in the cab?
If you need any help, let me know. I've got a soldering iron and plenty of spare wire and connectors if you need them.
Good deal, now it seems like I can finally get this done! I am not electrically smart so that was holding me up some. All I need is the inline fuse now, and I am going to connect it to my switch on the daystar panel. Where can I get an inline fuse and aren't they already connected to a partial wire that you can splice into?
When you install the bracket from JeepSwag, make sure you turn off the engine, and pump the brakes repeatedly to release the vacuum from the brake booster.
I didn't and when the master cylinder was loosened, the o-ring got sucked into the booster. I couldn't get a good seal and went without power brakes for a week until the problem was figured out.
I'm actually hardwiring my compressor and running the wires for my amp tomorrow. You're welcome to join me and we can get your done too. Just let me know...
That would be great but I have work at 2 tomorrow Yall have got me thinking about buying the Jeepswag mounting bracket for under the hood now Might be easier with having to run less wire and that. Thanks for the offer. If I get the mounting bracket I might give you a buzz and see if we could get together then. Thanks again
