plasmaglow wiring question
It doesn't have to be that way, on the diagram above it shows you can do any number of things depending on personal preference. Having the switch on constant with accessory power is just another way to do it. Jumper between + and C would achieve a constant LED on the switch
Sent from my LG-LS980 using JK-Forum
Went and pulled mine from the box. White is output (labeled C and jumper to +) Red is 12v+ (labeled NO) Black is ground (labeled -) This is how it's wired so that when the lights are on the ring lights up
After trying a hundred different combinations, it seems you can't have these rings light up on accessory and stay on with the button depressed.
Thanks WhiteGhost for all your help!
