Pioneer AVIC F-Series Help
i dont believe it does, because the one for the infinity system just gives you rca's to plug into for the amp....if your rewiring the whole system then you only really need power from the harness....well at least that is what i remember so not 100% sure, someone else needs to clarify. i bought the cht0-03 one but ended up getting a new amp so i didnt need the rca's that the harness provided.
i installed my one. it is a lot of wires but a write up wouldnt rele help, it would take way to long for each wire
it looks indimidating but rele theres not much to it, plug in the harness (i used chto-03) and connect wires/rca's as shown on the install booklet. the only one which didnt work for me was the revers wire but that was an easy fix.
i say go for it, just take your time and double check stuff
