Pioneer AVIC F-Series Help
Old 03-24-2009 | 11:00 AM
Klietable's Avatar
Default Pioneer AVIC F-Series Help
Does anyone who has installed one of these have a comprehensive write-up? It looks a little intimidating with the amount of wires that it has.
Old 03-24-2009 | 11:09 AM
scotlandjk's Avatar
i installed my one. it is a lot of wires but a write up wouldnt rele help, it would take way to long for each wire
it looks indimidating but rele theres not much to it, plug in the harness (i used chto-03) and connect wires/rca's as shown on the install booklet. the only one which didnt work for me was the revers wire but that was an easy fix.
i say go for it, just take your time and double check stuff
Old 03-28-2009 | 09:32 PM
Klietable's Avatar
So I hooked everything up according to the instructions, and No Power!
Anyone have any suggestions? Haven't tested the wires yet with a meter, but since everything was new out of the package, I'm more inclined to think I made a mistake.
Any help would be appreciated.
Old 03-28-2009 | 10:09 PM
The Assassin's Avatar
Check out avic411.com
Old 04-06-2009 | 10:56 AM
lunkhead22's Avatar
Before you install the f90bt you might want to bypass the dvd player option. If you want you passengers to be able to watch dvd's will driving. You can find the info on avic411.com I did to mine, I am currently modding the software to have a jeep on the navigation screen.
Old 04-06-2009 | 10:57 AM
lunkhead22's Avatar
What are you going to be using the accessory lead for?
Old 04-06-2009 | 11:06 AM
lunkhead22's Avatar
Here's mine
Old 04-28-2009 | 12:32 PM
jk4door's Avatar
Originally Posted by lunkhead22
Here's mine
Which wiring harness did you use? I've read about people using the chto-03, but crutchfield told me to use C2R-CHY4. Any ideas if this one will work?
Old 04-28-2009 | 05:17 PM
Vernnz's Avatar
CHTO-03: For use with factory amplified systems.
C2R-CHY4: For use with factory amplified or non amplified systems. Includes interface for Navigation and Steering Wheel COntrol (SWC).
XSVI-6522: For use with non factory amplified systems. You didn't ask but this is the one I used to install a Kenwood DDX-812.
Old 01-09-2010 | 11:47 AM
Phishjeep's Avatar
Does it matter which harness you need if you are replacing the stock infinity amp with a new amp at the same time the head unit is replaced?
