Pillar gauge pods
#32
Well, just to show off...
Did have to make a 2nd one, because the first was not sized right (guess I shoulda waited until I had the gauge in hand, haha...) - just needs sand/prime/paint now.
I probably won't finish it until later this month, going on vacation this weekend and will be out of town until the 15th.
All I got is crappy cellphone pics....
#35
That looks great, good job!
I'd actually like to see someone do something similiar, but including the piece above it and making it one and having places for 4 gauges. I think that would look really cool and get just about everything you need covered.
#36
ONE gauge does ALL this!
# RPM
# MPH
# Intake Air Temperature (post Intercooler)
# Ambient Air Temperature (pre Intercooler)
# Engine Coolant Temperature
# Exhaust Gas Temperature (PCM Calculated)
# Transmission Temp. (auto trans)
# Manifold Pressure (vacuum/boost) displayed in PSI
# Fuel Temperature
# Battery Voltage
# Battery Temp
# Injector Pulse Width in msec.
# Injector Duty Cycle (%)
# Air Flow Rate into engine
# Long Term Fuel Trim
# Short Term Fuel Trim
# O2 Sensor Voltage
# Barometric Pressure
# Ignition Advance
# Base Spark
# PCM Spark Adjust
# Fuel Status (open/closed loop)
# Wastegate Solenoid Duty Cycle (%)
# Knock Retard
# Knock Sensor Raw Voltage
# Throttle Position Percentage
# Throttle Position Sensor Raw Volts
# Calculated Net Horsepower
# Engine Load
# Transmission Slip
# Current Transmission Gear
# Torque Delivered to Transmission
# Torque Converter lockup status
# Brake pressure
# Brake Booster Travel
# Steering Angle
# Non-driven Wheel Speed
# Lateral G's
# Yaw
# Fuel economy (instantaneous and average)
# P-ratio - pressure ratio MAP/Barometer
# 2 user configurable analog inputs**
#37
lol I know they do whpony, but I kinda like the clutter to be honest and like seeing everything at once. The interceptor is definitely very cool though and given the options currently available looks to be a great choice for most people's needs.
