PIAA 525 fog/driving lights
Looking for info from someone who got the relays tied into the high/low beam signal so that their PIAA 525 will shift down to fog when you dim to low beams.
I tied into the two hot wires in the back of the headlight assembly but then found that both are hot when the lights are on in dim and bright so it doesn't work as a control signal to the relays for the PIAA lights. They must be switched with the switch in the cabin between driving and fog.
Any input?
Any input?
