Peterson Led Headlights
Yes. There are a few threads on them. Here is one.
https://www.jk-forum.com/forums/jk-e...lights-298791/
I installed them a couple weeks ago. Breezy-easy install. Fit great.
What concerns are you finding?
First I broke the clip as I was taking out the original light. After installing it looks like there is some space between the new LEDs and the jeep. I going to take a picture that will better explain what I am talking about.
What folks have often done with the various 7" universal headlamps when they run into firmer issues is use some electrical tape. Put a layer or two of electrical tape over the headlamp assembly tabs before placing the trim ring back over the light to lock it down. This can make a more firm fit.
I've had my Petersons in for a few weeks with no problems. When I first installed them, one side was a little loose and I couldn't figure out why. So I switched the lights around and now they're tight and fit perfectly. You will love the light output. Literally night and day from the stock lights.
Arjeeper - have you replaced your fog lamps yet? I'm trying to find something that will work and have the same color as the Petersons. It's strictly for looks so I don't want to break the bank if possible. Let me know.
Nokya PSX24W 2504 Fog Light Bulbs - Arctic White 7000K 24W (Stage 1) NOK7491 by Nokya http://www.amazon.com/dp/B00K6Q2JTI/..._nSlFtb0A5JRW4
Also, many of the LED options are simply too bright. Fogs don't work if you're binding people.
