Parking Bypass question
Ok I bought a parking brake bypass from amazon, but i have not installed it yet. I am gonna use it but i want an "emergency" switch hidden so if i get pulled over I can hit the switch and it will shut down the video. Ok the question is can i install a toggle switch to connect to one of the 3 wires coming from the little bypass (power, ground, and parking brake) and the bypass only, so the toggle switch will be connected directly to the bypass, before the connection to the HU, and be able put a toggle switch there and mount it. That way if have a movie is playing you can flip the switch and it will disable the bypass, but you can still have a fully functional radio when the bypass "toggle" is flipped off? Then say when the "authorities" leave you can h it the toggle back to the play position and be back to watching video's.
You need more than a parking brake override. The system also gets speed from the Jeep's ECM, so as soon as you start moving the radio will lock itself out from showing video. This is how the Lockpick unlocks it, by intercepting the speed signal and sending a speed of "0" to the radio, so it will let you operate it as if it were standing still.
Get yourself a "lockpick" device. Plug - n play , unlocks many more features on the MygIg units , allows for backup camera and 2 more. And no wire hacking. Assuming you are talking about the factory DVD/Nav HU that is?
Its a Pioneer AVH-P2400BT, from everything I have read it states that a parking brake bypass is all I need. This is the first time I have heard about the "lockpick" mechanism... The link below is to the bypass that I have purchased. Amazon.com: PIONEER VIDEO BYPASS FOR AVH-P1400DVD AVH-P2400BT AVH-P3400BH AVH-P4400BH: Electronics
Thank you for your help and inputs!
USB UPDATE ABILITY - STAY CURRENT WITH FUTURE MYGIG AND LOCKPICK UPDATES
NEW PERFORMANCE TIMERS ALLOW YOU TO TRACK YOUR VEHICLE ACCELERATION FROM 0 TO 60 MPH MEASURED IN 100THS OF A SECOND OR MPH REACHED IN 10 SECONDS!!
DVD PLAY WHILE IN MOTION - AUTOMATIC OR ON DEMAND
SAT TV ON FRONT SCREEN WHILE IN MOTION (IN EQUIPPED VEHICLES) - AUTOMATIC OR ON DEMAND
NAVIGATION ADDRESS INPUT WHILE IN MOTION (IN EQUIPPED VEHICLES) - AUTOMATIC OR ON DEMAND
UNLOCK EVEN DEALER BLOCKED VIDEO - EVEN IF YOUR VIDEO BUTTON IS NEVER VISIBLE THE LOCKPICK WILL EXPOSE AND UNBLOCK IT
TURN ON BACKUP REVERSE CAMERA INPUT FOR AFTERMARKET INSTALLATIONS
TURN ON FACTORY REVERSE CAMERA AT ANY TIME, EVEN IN DRIVE IF DESIRED
TURN ON A REAR SEAT BABY CAM AT ANY TIME
TURN ON A FRONT CAMERA AT ANY TIME
TURN ON A FRONT CAMERA AUTOMATICALLY BELOW 8MPH TO AID IN PARKING
OPTION BUILT IN FOR TURN SIGNAL CAMS - ACTIVATE AUTOMATICALLY WHEN TURN SIGNAL APPLIED, OR TURN ON LEFT OR RIGHT SIDE CAM MANUALLY AT ANY TIME
TURN ON VES (REAR ENTERTAINMENT MODE) IN NON EQUIPPED VEHICLES - ENABLES A VIDEO AND AUDIO INPUT FOR YOUR IPOD, IPHONE, COMPUTER, OR VIDEO GAME
AUX INS UNLOCKED IN VES EQUIPPED VEHICLES WHILE IN DRIVE
UCONNECT AND VOICE RECOGNITION ENABLED ON CAPABLE NAV RADIOS - JUST ADD A MICROPHONE AND YOU ARE READY TO GO SEE MICROPHONE OPTION HERE
NO SWITCHES TO ADD - USES FACTORY TOUCH SCREEN AND RADIO BUTTONS AND STEERING WHEEL CONTROLS
NO LOSS OF NAVIGATION USE WHILE UNLOCKED - VOICE COMMANDS AND MAP TRACKING UNAFFECTED - EVEN WHILE VIDEO IS VIEWED
ACC POWER OUTPUT PROVIDED FOR YOUR AFTERMARKET POWER NEEDS - TURNS OFF WHEN YOUR CAR TURNS OFF
CAMERAS POWERED AND CONTROLLED BY THE LOCKPICK - NO NEED FOR COMPLICATED WIRING OR EXTRA SWITCHES
PROGRAMMABLE DIP SWITCHES TO ENABLE OR TURN OFF SPECIFIC FUNCTIONS
NO CUT WIRES - 15 MINUTE INSTALL WITH PLUG AND PLAY FACTORY CONNECTORS
GREAT FOR LEASED CARS!! - UNPLUG IT AND YOUR CAR IS BACK TO STOCK
WORKS WITH ALL MYGIG RADIOS IN ANY CHRYSLER DODGE JEEP INCLUDING MANUAL AND AUTOMATIC TRANSMISSIONS - ADVANCED UNIVERSAL COMMUNICATIONS
MYGIG LOCKPICK
This will depend on if you have an iPhone 5 or not. The iPhone 5 removed the analog video output connections that were available on previous iPhone's. The iPhone 5 uses the new lightning connector which is all digital.
Go to AVIC411.com. It's a Pioneer forum. They have all the hacks for the nav systems. Used to have Pioneers in my Vette (RIP) and F150. Don't waste your money on those Amazon.com or ebay bypass scams. They have step by step procedures to unlock your HU without buying any lockpicks or bypasses. I have a Kenwood now and all I have to do is ground the parking brake wire.
