PAC harness adding aftermarket amp
While I understand this isn't the best way to do this (there's a FANTASTIC write up in the forum bypassing the stock system) but it would be the easiest.
I also understand that the PAC harness will not allow you to change the tone for the sub box, but can you still control the tone for the stock speakers still connected to the infinity amp?
Do what you want. It is your stuff you messing with.. This is my experience and opinion, as I only want to help. A lot of times you get a cleaner sound and can get a little bit louder without the bass boost and upping the gain a little. Your frequency and subsonic filter are key too. Sometimes you just need more power. Wait, isn't that all the time???
You don't wanna use the bass boost on any amp. While you may have had good luck before with the boost, it's not a good option for adding more punch. The boost actually adds a little more oomph through distortion. Distortion that can lead to damage or failure of the speaker or sub attached. You should be able to safely turn the gain up to half, sometimes more, on most amps without distortion. Most people like the frequency on a sub amp around 80-100. Your gain controller is specifically to gain the amp back to 100% or anywhere else in between.
