Outside temperature and direction display
Gak! Unfortunately, I can't give you a link to this. But, I just "built" two 4-door 4x4 Unlimiteds on the Jeep.com website. One with the S package, one without. I'm looking at a matrix comparing the two. Here's what's added:
Dual Top Group
Electronic Rear Locking Differential
Remote Keyless Entry
Temperature and Compass Gauge
Fog Lamps
Security Alarm
Tubular Side Steps
Chrome Tubular Side Steps (and, no, this is not a Sahara)
Speed Control
uConnect
Leather-wrapped Steering Wheel
Electronic Front Sway Bar Disconnect
Freedom Top (duh!)
Front and Rear Tow Hooks
17" Wheels
There can also be added to the S package model:
Rear Window Defogger
Rear Window Wiper (wish I'd had the option to leave this off my JK!)
So, that's a lot different than the 2007 S package, because I did not get dual tops, side steps, a security alarm, electronic front sway bar disconnect, rear lockers, 17" wheels, keyless entry.
Dual Top Group
Fog Lamps
Security Alarm
Tubular Side Steps
Speed Control
uConnect
Freedom Top (duh!)
17" Wheels
My moms Grand is always pretty close and usually only 2 or 3 deg off at most. I think it might have something to do with it taking a little bit to change the reading after the temp has actually changed. (ie the temp was a little different from where you were coming from and not exactly the same as the banks temp gauge. Not sure though. Also I have never seen a DTE that has worked very good. I would never trust one either.
