Opening Garage Door With High Beams
Old 06-14-2014 | 07:12 AM
Twinkydog's Avatar
As stated above. Use a 12v relay. Tie the coil of the relay to your headlight circuit where you have your controller wired now. Then put a constant 12v from the battery on one side of the relay contact and your controller on the other. This way when you turn on the high beams you actuate the relay and put the constant 12v on your controller. Let us know how it comes out, very creative solution.
Old 06-14-2014 | 02:29 PM
rrreed's Avatar
Thank you for your reply. A quick question.. do you think that the opener would get constant voltage with the high beams on ? Should I use a momentary relay?
Thanks
Old 06-14-2014 | 02:54 PM
Twinkydog's Avatar
Originally Posted by rrreed
Thank you for your reply. A quick question.. do you think that the opener would get constant voltage with the high beams on ? Should I use a momentary relay? Thanks
. Yes, the opener will get constant voltage with the high beams on. I really doubt that is going to cause you any problems though. You would be getting into a specialized logic circuit for it to work otherwise. A momentary relay is what most relays are, they stay engaged as long as power is applied. I would just run what you have.
Old 06-15-2014 | 05:21 AM
azsandrider's Avatar
Or:
Open your garage door with your SmartPhone or headlight highbeam Flash2Pass
Quick Reply: Opening Garage Door With High Beams
