Old man needs better sound!!!
I would like to retain my basic stock head unit in my 2013 Jeep Sport 2dr. I have very little knowledge when it comes to stereo systems so hang in there. A friend of mine sold me a Audiocontrol LC6I line out converter that he said I would need between my head unit & amplifier. I know there are cheaper ones, but he gave me a good deal. From what I understand, I should take a set of RCA's and cut the ends off one end, and then tie into my rear speaker wires, then plug the RCA's into my amp? How do the speaker wires for the sound bar run? Do they come down from the dash along the transmission tunnel or down along the doors? I bought 4 Rockford Fosgate 6.3/4" Punch speakers and a set of Polk tweeters to replace the factory stuff.
Thanks for your input!!
Please don't cut the ends off of the RCA cables and splice them in that is the exact wrong way to do it. Amps need a different frequency than regular door speakers that's why you bought the line output converter LOC. You will have wires on your loc that tap into the factory speaker wires. If you are powering door speakers you will tap into the front and rear speaker wires. That is assuming your amp is 4 channel and your loc is 4 channel. The RCA wires will run from the loc to the amp and the speaker wires run from the amp to the speakers. The amp also must have a large power wire run from the battery a good ground and switched/remote wire.
I'd do it once and ditch the headunit. I wasn't happy at all with amp/ speakers off stock headunit. It had no mid/ low sound at all. Just sounded like laptop speakers.
I'd recommend you run speakers off new headunit, and a small sub off a mono amp for good full sound. I ended up doing this in two steps and paid out the ass for it.
I'd do it once and ditch the headunit. I wasn't happy at all with amp/ speakers off stock headunit. It had no mid/ low sound at all. Just sounded like laptop speakers. I'd recommend you run speakers off new headunit, and a small sub off a mono amp for good full sound. I ended up doing this in two steps and paid out the ass for it.
But yes tap the loc into the speaker wires then you have to run 2 sets of rcas into the amp if you have a 4 channel amp. If the loc is only 2 channel then you could technically put y connectors on one RCA and split it to the front and rear inputs for the amp. Might not sound the best but it will work.
By running all your speakers off the rear chan I assume your loc and amp 2 ch which means all your speakers will be rear speakers technically. You will have louder speakers but the quality will suffer. You truly need a 4 ch amp and a 4 ch head unit or loc to get more sound and good quality. If you insist on running off the rear ch just tap your loc into the rear speaker wires, I think they run on the passenger side.
I have a alpine 4 channel amp & the LOC is a 6 channel. I do have an Alpine head unit I had in my previous vehicle, but it is a single din, and don't like the dash kit with the storage box. I did want to keep it looking stock, but if it would make that much difference I would go ahead and put it in. Thanks for the help!!!
Follow the other advice and use an aftermarket head unit. He is right, the stock one sounds like garbage. You can get a double DIN touch screen without Nav for a few hundred bucks that will sound better, has better BT connectivity, better iPod/iPhone control and will work with your steering wheel controls. I spent $500 on Pioneers top of the line DVD touch screen at the front face comes off for the times I leave the top off. I have never used the DVD player, but the iPhone controls are excellent.
I'm and old guy too and if I were you, I'd regroup and do it right the first time. Ie: new head unit, separate amps (use the one you have - 2 channels to power the front speakers, HU power the sound bar, 2 channels bridge for the sub or get a new 5 channel amp), component speakers in front, the RF coax are fine for your sound bar but not for the front, and figure out a suitable sub (in stock location, under the back seats or under the front seats). The closer you can locate your sub to the front seats the better bass you will have with the top off. Search for Dave, he makes a killer rear seat box and I have my subs under my front seats. The two best locations in my experience. Do yourself a favor and do it right.
Be careful, take your time and do research. If you keep your stock HU, DO NOT tap into the rear speaker outputs since they have limited bass output and decreased volume output with the top off. Follow the other advice and use an aftermarket head unit. He is right, the stock one sounds like garbage. You can get a double DIN touch screen without Nav for a few hundred bucks that will sound better, has better BT connectivity, better iPod/iPhone control and will work with your steering wheel controls. I spent $500 on Pioneers top of the line DVD touch screen at the front face comes off for the times I leave the top off. I have never used the DVD player, but the iPhone controls are excellent. I'm and old guy too and if I were you, I'd regroup and do it right the first time. Ie: new head unit, separate amps (use the one you have - 2 channels to power the front speakers, HU power the sound bar, 2 channels bridge for the sub or get a new 5 channel amp), component speakers in front, the RF coax are fine for your sound bar but not for the front, and figure out a suitable sub (in stock location, under the back seats or under the front seats). The closer you can locate your sub to the front seats the better bass you will have with the top off. Search for Dave, he makes a killer rear seat box and I have my subs under my front seats. The two best locations in my experience. Do yourself a favor and do it right.
I personally don't see the need for a detachable face on a double din as you screw the mounting brackets into the side of the radio and then screw the radio into the factory mounting points in the dash which are behind the face trim. Takes a lot more work and time to rip it out. But I have an aftermarket remote start and alarm so a slight bump in my jeep and it goes crazy and alerts my keychain.
So you can do it right both ways but I would double tap on pair of speakers to run all 4 if you don't have to.
