OffRoad Lights wiring questions
Old 01-30-2010 | 04:23 AM
Will's Avatar
Default OffRoad Lights wiring questions
I'm adding offroad lights to my front bumper and have a question about wiring them up. I wired lights up on my Yj and Tj but can't remember exactly how I did it. I've installed the switch and relay and ran power from battery to both. I installed the lights and ran a wire from relay to them. My question come with grounding. I grounded the relay to a bolt connected to the body near the fuse box, wired the ground on the switch to a bolt behind the dash panel. I have read to ground the lights to the bolts that hold the lights in place but I have also read to run all grounds to the negative terminal on the battery. Please advise.
Old 01-30-2010 | 04:30 AM
Hilldweller's Avatar
This should help.
Old 01-30-2010 | 05:21 AM
Will's Avatar
Thanks for the diagram. In this diagram, the grounds are grounded to the vehicle, not the negative terminal on the battery. I will connect everything and give it a shot.
Old 01-30-2010 | 07:38 AM
6 or a half dozen; it's easier to ground to the frame and, if your grounds are clean, yields the same result.
Old 02-19-2010 | 08:34 AM
Riptide's Avatar
Originally Posted by JEEP GREEN 4DR
Looking to add 300W of light to a bumper bar. My question is this:
If I have 300W/12V = 25A (uh, right?)
So, if I run from the battery to a 25A fuse, then to an illuminated switch rated for 25A and out to the lights, do I really need a relay?
I'm not sure what 300w of lights will cost you... but you may want to have a look at some HIDs.
Old 02-19-2010 | 09:07 AM
Hiball's Avatar
300W and a 25 amp fuse??? I'm not sure if that'll work, when I put my KC's on with 130w they gave me a 40amp relay.
Old 02-19-2010 | 09:55 AM
horwitzs's Avatar
I would want the switch to be rated higher than the fuse. If they are both rated the same, then either one could act as the fuse and get fried.
The fuse should be the weakest link, so it will for sure be the place to fail.
Old 02-19-2010 | 11:36 AM
JK-Ford's Avatar
I wouldn't recomend applying that kind of a load to a switch. Even if it is rated. They tend to get hot. Best to use a relay.
Your calculation is correct. I asume that you are refering to two 150 watt lamps?. Use #10 awg for power from the battery. You can use a 30 amp fuse. Use #14 awg to each light seperatly. You could use one #10 awg. But bigger wire is harder to work with
Old 02-19-2010 | 01:10 PM
ckmehl's Avatar
Default do a
just go right to a 100amp wafer fuse and call it a day!
Old 02-19-2010 | 01:33 PM
tazzdogsocal's Avatar
hope I'm not to late . heres a link to a calculator http://www.crownaudio.com/apps_htm/d...s/ohms-law.htm
Quick Reply: OffRoad Lights wiring questions
