OEM infinity with aftermarket Deck
Old 03-25-2009 | 09:59 PM
VEGASSMAN's Avatar
Question OEM infinity with aftermarket Deck
I think I found what I needed.
Description
CHRYSLER TURN-ON ADAPTER
Product Specifications
-2007 Dodge Nitro & Jeep Wrangler amplified system
-12 volt accessory output
-Retains RAP if equipped
-Adjustable input gain
-Navigation outputs now included
-USB update interface compatible
The CHTO-03 interface is designed to allow the user to replace the OEM radio with an aftermarket unit in select amplified 2007 Chrysler and Jeep vehicles and retain the use of the OEM amplified audio system. The CHTO-03 will also retain the retained accessory power convenience features if the vehicle is so equipped. In addition to these features, the CHTO-03 now has the required outputs for the installation of a navigation radio.
$79.99
That should address the wiring issues.
Now I just need to decide on a nice Double DIN unit. My only "must have" feature is the front USB port so I can just play music of flash drive media.
I think this Kenwood is a pretty good deal for $239.99:
sonicelectronix.com/item_16444_Kenwood+DPX503.html
Any tips on a good head unit that's in that price range? I don't want to go over $250 for it.
Last edited by JackMac4; 03-26-2009 at 05:31 AM. Reason: do not post direct links to non-sponsors!
Old 03-26-2009 | 05:31 AM
JackMac4's Avatar
Yes, you've got the right adapter picked. The CHTO-03 is what you need. FYI, there are also adapters made by PAC and Peripheral. But you'll need one of them to add an aftermarket HU to your Infinity system.
Quick Reply: OEM infinity with aftermarket Deck
