OEM Electronic Swaybar Disconnect
#21
"To disconnect the stabilizer/sway bar, shift to either 4H
or 4L and press the SWAY BAR switch to obtain the
off-road position."
Is this in error?
The mode of failure usually is corrosion in the connector on the e-disco, and failure of a component on the circuit board inside the e-disco, often due to water intrusion.
#22
Water, makes sense!
Mine just failed last weekend and it would not re-engage. Had a long snowy drive on the highway home and it was a little sketchy at times. I will see if Chrysler will do anything about it, and thank you for the tip. That manual conversion is awesome.
#23
Originally Posted by 4-Lo
It's only 4-lo on the newer ones. I guess the old ones were different? I'm wondering if anyone has any indication as to what makes the power disconnect fail. Is it just poor engineering? Trying to disconnect and/or reconnect when on uneven ground?
Anyone ever tried coating the whole connector with liquid electrical tape? It seems to be the main source of failures.
