OEM Electronic Swaybar Disconnect
Old 10-31-2012, 01:18 AM
Daptodog's Avatar
Been there, done that! No point to argue! Running Evo manual for while. Chrysler Australia told me same thing! Misuse within warranty in 3th year. The punch line is they asked me for $7500 Australian Dollars not fitted! Talking year 2010. So warranty or not you betta off going with AEV&EVO combo!
Old 10-31-2012, 01:22 AM
Maritime's Avatar
What are the benefits of this combo? I was just going to go with the EVO manual Swaybar.
Old 10-31-2012, 06:13 AM
ronjenx's Avatar
Wasn't your original question about how to turn off the blinking e-disco light? That's what the AEV Procal will do, as mentioned in an earlier post.
Old 10-31-2012, 07:29 AM
Maritime's Avatar
OK, I just wasn't sure what that was. I'll look it up and do some research. Thanks for all the replies to this thread guys!
Old 10-31-2012, 07:42 AM
Zroe's Avatar
I replaced the motor in my 2011 Rubi with the manual screw. It was working fine, I just wanted to be able to disconnect in something other than 4-Lo, and up until 24 hours ago, you couldn't get a Tuner for a 2011.
The install was a breeze and it has been working flawlessly for about a year now. It's super easy to screw and unscrew. I placed a plastic glad freezer bag around the electrical connection and zip tied it out of the way.
I may be remembering things wrong, but I don't believe I had my AEV Procal at that point, and I don't think I ever had the swaybar light come one. However, mine was working fine before hand. Maybe since yours was broken first, your light is staying on?
Old 10-31-2012, 07:45 AM
ronjenx's Avatar
Yours wouldn't disconnect in 4hi?
Old 10-31-2012, 07:48 AM
Zroe's Avatar
Err, I don't think so. Was it supposed to?..lol..maybe I missed something.
Old 10-31-2012, 07:53 AM
ronjenx's Avatar
The e-disco will operate in 4hi and 4lo. However, it's more apt to fail than the manual mechanism you installed.
I converted an e-disco to manual, with a lever in the cab. It's not installed yet, as the OEM e-disco has not failed.
https://www.jk-forum.com/forums/modi...manual-161490/
Old 11-01-2012, 12:50 AM
Maritime's Avatar
Thanks for the link I'll give it a read
Old 11-01-2012, 06:49 AM
4-Lo's Avatar
It's only 4-lo on the newer ones. I guess the old ones were different? I'm wondering if anyone has any indication as to what makes the power disconnect fail. Is it just poor engineering? Trying to disconnect and/or reconnect when on uneven ground?
Quick Reply: OEM Electronic Swaybar Disconnect
