Odd issues with interior lights
I'm having an odd issue with my interior lights. When I signal right my interior light go to the brightest setting for a second or so also when I apply a bit of pressure to to end of the signal lever it will trip it up as well. Everything is fine when I signal left. This happens when my lights are on including the headlights and fogs. I usually have my lights on auto but this will happens even if I just turn them on manually. Any thoughts in what my be going on? I'm thinking the signal lever is just messed up creating a short or something. It's going to the dealer wednesday to get looked at and a new driveshaft to. I just wanted to see if anyone has had a similar issue.
In no way have I altered the factory wiring.
It's a 2011 rubi .
Thanks
It's a 2011 rubi .
Thanks
Sounds like the lever is shorting out. Might be a stray piece of metal, wire, or just bad contacts grounding it out. I work on F/A-18 hornets for the Navy and we have stuff like this happen all the time with switches on a $90,000,000 aircraft so our $30,000 jeeps are definitely vulnerable these nuances.
