Northridge ipf bulb and reflector package
Can someone help me figure out the ipf setup options?
I'm going with the northridge setup and not sure if these bulbs are white or the bluish tinted ones and what bulb type I have to choose from going forward...
I searched and read a LOT of them but did get enlightened...no pun intended
Matthew
Matthew
The kits with the bulbs are the bluish ones, at least mine were. But the light is more white with a slight blue tint. If you replace them one at a time, you will see how crappy and yellow the factory light is. I will probably try the Phillips extreme bulbs next...
The bulbs have a blue tint to them when they're off. When they're on however, they're white. The bulbs the packaged with the kit from Northridge (same as Quadratec and others) are 4400K.
If you do a google search for headlight bulb color you'll find a lot of side-by-comparisons on color temperature
