Norn Not Working
Norn Not Working
I have been having some horn problems.. from time to time my horn stops working. Today I noticed that when the horn is not working there is a clicking sound at the fuse box when you try to honk it.
Is there a horn relay switch in the fuse box? Seems like thats the problem..
I called Chrysler but they will not give me information over the phone as if they where a doctors office or something. They told me I need to make an appointment that means I miss work, I can't do this. so it's up to me to fix yet another problem with this Jeep
Originally Posted by tford911
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=198797"/>
the main reason is the alarm is working on the horn.
2nd reason is people are retarded and love to back into people in Vancouver BC
and somehow ICBC makes that your fault haha Horn is needed for sure
Originally Posted by centerfieldr162
Norn
all I have to say is "DERP"
The horn fuse is inline after the relay, so if the fuse were blown, or had an intermittent connection, you would still hear the relay.
Go here to see more details on the TIPM (fuse box). https://www.jk-forum.com/forums/show...OEM-TIPM-Study
When the horn does operate, does it sound normal? Sometimes water or dirt in the horn will prevent it from working.
Check all the connections between the TIPM and the horn for looseness or dirty connector pins.
Originally Posted by ronjenx
Below is a picture of the horn relay. If it clicks when you press the horn button, the clockspring in the steering wheel must be OK.
and yes it's a new horn I have had a few that ended up sounding like a dying dolphin due to mud and water.. some i was able to dry out and re use.. i have been through 3 horns in 50000km
Is there a Fuse Box diagram anywhere for the small fuses?
