Is this normal for heater?
When I turn the dial for the air I blow on both the face and the feet, the air to the feet is minimal. They work great individually. There is about the same (maybe a little less) air pressure coming out of the feet when turned on face/feet on high as there is when it's just the feet on as low as it gets.
Hopefully that makes sense. I have not tried to see if it does the same thing when cold air comes out.
Pretty much the same here...-22 this morning heat was pretty much full blast...
Much better than the 08 JK i had...
The heat that i do have is insanely hot...
