No more OEM sub. Help!
Hi everybody! I'm about to say good bye to the crappy stock 8" infinity sub and putting in 3 12's in the back with a 500/1 JL. Now my question is where do I go about bringing the power wire through the firewall? Pictures would be GREATLY appreciated!
![Cool](https://www.jk-forum.com/forums/images/smilies/cool.png)
On either side of the dash there is a panel. You can pop it out with a plastic tool or twist the drivers side vent, remove it, then push the panel out with your fingers. If your using 4 gauge you should be fine. I used 0 gauge and drilled a hole on the passanger side, low, and added a grommet. Sealed it with 3M tape caulk.
Better share pics when done
![Clap](https://www.jk-forum.com/forums/images/smilies/clap2.gif)
