New OBD2 gauge installed - Aeroforce Interceptor
#191
got my gauge pretty cool .. still trying to figure out how to completely turn off the tpms light.. i put all zeros in .. but the light still comes on .. can you turn the light off if you don't have the sensors ? thanks
#192
Can someone tell me if the gauge will read Oil Pressure or Oil Temperature on the JK or will I have to buy the additional sensors?
#193
#194
oil temp for auto trany only
if you want oil pressure and temperature for engine you need add on sensor for the Interceptor 5 volts aux connectors
as for tpms you 're getting the system error or the low pressure light on ?
low pressure should be handle by the Interceptor adjustable pressure but the tpms error is a other story
#197
you will need additional sensors to read both engine oil temp and pressure but you can wire them into the two analog inputs and read them off the gauge.
I got the sensors from Aeroforce and got a Glowshift oil filter sandwich adapter to mount them on.
If I did it over again I would skip the oil temp sensor but I like having the pressure gauge.
#198
Thank's for the information!!
#199
i havent been able to set my tire size or turn off the tmps light ? anyone able to completely turn off their tmps light ? what number value would you put in for a 37 " tire that measures 36 " thanks
#200
Help with new gauge V3.5 not powering up on 07 JK Auto
Is the gauge end of the OBD2 cable just 4 wires? I have my gauge set for platform 2, and it powers up only upon first connection to the JK OBD2. I set up parameters, save, then plug/unplug and it stays on a few seconds, the two red leds flash twice, then it powers off and will not come back on without unplugging/replugging. Starting Jeep has no impact.
Thanks.
Thanks.
