New OBD2 gauge installed - Aeroforce Interceptor
Old 04-28-2010, 03:11 AM
  #191
blockrockin's Avatar
got my gauge pretty cool .. still trying to figure out how to completely turn off the tpms light.. i put all zeros in .. but the light still comes on .. can you turn the light off if you don't have the sensors ? thanks
Old 04-28-2010, 08:20 AM
  #192
yellow08rubicon's Avatar
Can someone tell me if the gauge will read Oil Pressure or Oil Temperature on the JK or will I have to buy the additional sensors?
Old 04-28-2010, 08:30 AM
  #193
i believe you need a separate sensor... but i dont think they cost very much... it will read trans temp without a additional sensor
Old 04-28-2010, 08:32 AM
  #194
Pape's Avatar
oil temp for auto trany only
if you want oil pressure and temperature for engine you need add on sensor for the Interceptor 5 volts aux connectors
as for tpms you 're getting the system error or the low pressure light on ?
low pressure should be handle by the Interceptor adjustable pressure but the tpms error is a other story
Old 04-28-2010, 08:35 AM
  #195
i am getting the low pressure sensor light .. i wasn't sure how to completely turn off the light .
Old 04-28-2010, 08:39 AM
  #196
Sorry, ENGINE Oil Temperature and Pressure!!
Old 04-29-2010, 06:34 AM
  #197
Jiblet's Avatar
you will need additional sensors to read both engine oil temp and pressure but you can wire them into the two analog inputs and read them off the gauge.
I got the sensors from Aeroforce and got a Glowshift oil filter sandwich adapter to mount them on.
If I did it over again I would skip the oil temp sensor but I like having the pressure gauge.
Old 04-29-2010, 10:49 AM
  #198
Thank's for the information!!
Old 04-29-2010, 04:07 PM
  #199
i havent been able to set my tire size or turn off the tmps light ? anyone able to completely turn off their tmps light ? what number value would you put in for a 37 " tire that measures 36 " thanks
Old 05-21-2010, 06:39 AM
  #200
kb7our's Avatar
Default Help with new gauge V3.5 not powering up on 07 JK Auto
Is the gauge end of the OBD2 cable just 4 wires? I have my gauge set for platform 2, and it powers up only upon first connection to the JK OBD2. I set up parameters, save, then plug/unplug and it stays on a few seconds, the two red leds flash twice, then it powers off and will not come back on without unplugging/replugging. Starting Jeep has no impact.
Thanks.
Quick Reply: New OBD2 gauge installed - Aeroforce Interceptor
