New OBD2 gauge installed - Aeroforce Interceptor
#171
Sweet I will check in to this now
#172
Todd was also talking about transfer case monitoring wonder what it is and if it made it in the final build, anyway received mine just need to find a POD and install this week end maybe
#173
Just got my aeroforce and cant figure out how to change the tire size. I can get to the control settings but I'm not sure exactly what unit of measure it is asking for for the tire size. I currently have the procal as well and have the tire size converted with it and it says like 2972 or something similar for "tire size" on the aeroforce.
Any ideas?
Any ideas?
#174
Any ideas?
Any ideas?
Do you have the instructions that came with the gauge? No hints there?
#175
Looks like u may be right. I'll have to run the numbers when I get home.
Another problem I have is with the tire pressure. I have it set to zero and the light still come on. I no longer have the sensors in the wheels and hope that isn't the problem. My procal took care of it very easily. Hope the same can be do be with the guage.
#177
I was reading through their (the Aeroforce) forum and saw that you could change between the two scales. What I am really concerned about is does our OBDII's put that information through? You can buy an optional pressure transducer kit but it requires a seperate 5V power supply!???!! That is really what is stopping me from buying the gauge but if it does display an accurate manifold pressure I'm in!
#179
Can you post the link to the "how to", to change the scale?
#180
Not really a how to but this is the link to the Aeroforce forum thread about MAP kPa MOUSE.... oops
(here's the link)
ht tp://aeroforcetech.com/forum/viewtopic.php?t=1152
Almost sounds like they had another parameter available for MAP. They were discussing a Gran Prix. Check the last post in the thread.
This is what is driving me crazy about the Aeroforce and the PLX multigauge. They display a lot of useless stuff from the OBDII and it seems to be real difficult to nail them down as to all parameters they do display, AND they are a wee bit expensive. I need manifold vacumn and pressure under boost and it looks like I would have to buy their mechanical transducer kit and a 5v power supply to get what I want. I can get a pretty good gauge for Vacumn/Boost for the cost of the transducer alone. (don't get me wrong the coolness factor of the Aeroforce makes me want one )
(here's the link)
