New OBD2 gauge installed - Aeroforce Interceptor
Old 09-10-2009, 04:22 AM
  #161
deconstructionist's Avatar
Originally Posted by MoridinTX
I bought a single gauge and it takes up the OBDII port. When I need to use my Flashpaq, I just unplug the gauge, make my changes with the flashpaq, and plug the gauge back in. No issues thus far.
Cant find the link just now but I bought what amounts to a OBDII--- " Y " jack splitter from some place like 'cables dot come' or OBDII cables dot com" for somthing like $15........... allows me to run both the Aero gauge and a scanmaster gauge at the same time. Just unhooked the port connector from its cradle & plugged un the Y splitter and have it all shoved up under the dash. Takes only about 20 seconds longer to get to it to remove one of the gauge cables if I need to re-program with the hypertech.......
Old 09-10-2009, 04:03 PM
  #162
hvilla's Avatar
Deconstructionist - if you remember the site, can you please post it?
Old 09-10-2009, 05:13 PM
  #163
MoridinTX's Avatar
X2, that would be a nice thing to have.
Old 09-10-2009, 05:32 PM
  #164
mattymat04's Avatar
its where he said i have a ? though with a y adapter for the port can u just plug the superchip or hypertech in and it will work just fine? anyone try this?
Old 09-13-2009, 08:23 AM
  #165
I'm about 97% sure it was off the site below...I was considering it from 3 places but IIRC it was this one. the 'splits' look the same but the main housing on mine looks ever so slightly different....... ((Non sponsor so hyperlink removed))
obd2cables.com/products/obd-cables/obd-ii-cables/cable-j1962m-to-2-j1962f-y-cable-1ft.html
Goes for $15+ some change and S/H and IIRC got it in about 4 days. Hope it helps.
Old 09-25-2009, 04:09 PM
  #166
Jiblet's Avatar
I am happy to report that I (finally) got around to installing the aeroforce oil temp and pressure sensors to accompany my interceptor gauge. (and ya, I got help with the wiring )
My question to you all: now that I am no longer (blissfully?) ignorant of my oil temp and pressure.... WTF should I be looking for??
Can anyone tell me what operating pressure or range I am looking for?
Same for temp. Is there a max I should be on the look out for?
I need some education here! many thanks!
Old 09-25-2009, 05:00 PM
  #167
ronjenx's Avatar
Oil Pressure:
At Curb Idle Speed* (Minimum with engine at operating temperature) 5 psi
CAUTION: *If pressure is ZERO at curb idle, DO NOT run engine at 3000 rpm.
At 3000 RPM 30-80 psi
Oil Temp:
No data as water temp is the critical parameter.
Old 09-25-2009, 06:26 PM
  #168
Jiblet's Avatar
Originally Posted by ronjenx
Oil Pressure:
Oil Temp:
Thanks, ronjenx.
Old 01-06-2010, 08:07 PM
  #169
ronjenx's Avatar
The AeroForce gauge for the JK is now being shipped with the ability to :
Reset tire size
Reset gear ratio
Reset TPMS threshold
Set idle speed for winching, etc.
If you have an older gauge, you can send it in for a reflash to include these features for $26.
Old 01-11-2010, 01:23 PM
  #170
Are the gauges working with the Unichip Plug n’Play Performance Computer Module installed?
Thank you
Quick Reply: New OBD2 gauge installed - Aeroforce Interceptor
